Replacement Sidecar Tire
Quote from Guest on November 2, 2009, 11:43 pmFor those who run a 145SR13 tire on thier sidecar and need a replacement,these tires are hard to find....A more updated number for these tires are
145/80-13 and are a little bit easier to find......same size,newer designation.... just got a new Yokahama car tire for 50 bucks shipped.....DOT code is recent and tire is soft and new with label..... 😉
Quote from Bigbikerrick on November 4, 2009, 9:47 pmThanks Bro, just what I was looking for, I put the larger size tire on my Cali F2, and its a little too tall, I wonder how much difference in height the 145 is than the 155?? Rick.
Quote from Hack__n on November 4, 2009, 11:28 pmIf your tire clears everything the larger size will just last a bit longer. The difference in heigth can be taken care of by readjusting the sidecar mounts back to level.
Quote from Guest on November 20, 2009, 12:52 ammy cali 1 runs a 155/60/13,..155 is the width,..60 is the rim/height profile difference,.. and 13 is the rim diameter,..a 155 will offer 1/2 inch wider tread pattern to the road, backspacing may be required for extra wide pattern,....good luck, crawf.
