Plastic part to join windscreens and sidecar cover
Quote from Roulemabosse on June 6, 2017, 9:35 amI own a Vetter Terraplane sidecar.
I need to find the part (or to adapt something) which joins the front windscreen and the side widescreen of the sidecar (see pictures attached).
I also would like to add a cover to ride under rain with my kid. Any picture or idea how to do it?
Thanks.
Thanks.
Quote from IndSlim on June 6, 2017, 9:35 pmI can't help you with the parts, but I will share a tip: To keep the cracks in your windscreen from continuing to travel, drill a very small hole at the terminus of the crack.
Good luck.
Good luck.
Quote from Al Olme on June 6, 2017, 10:22 pmThe picture looks like two pieces of "J channel" glued back to back. You might want to check out this...
https://www.mcmaster.com/#trim-molding/=17yilev
Scroll down to "trim for connecting panels" for a start but poke around, you might find something you like better.
Good luck!
Good luck!
Quote from OldSchool_IsCool on June 7, 2017, 1:42 pmOr maybe search the web for anyone selling small quantities of H-channel.
This is just an example, I have no info on this company so I can't comment, positive or negative on them.
http://www.acmerubber.com/hchannel.htm
Quote from Roulemabosse on June 7, 2017, 4:31 pmThank you for your input, I will check that.
Quote from 85shadow on June 7, 2017, 10:25 pmI have a Terraplane also ( a new acquisition ) it has aluminum channels, maybe shower door? I'll try to get a pic and post it.
Quote from ocpd44 on July 6, 2017, 7:27 pmYou don't say where you live but, if you around water, take your car to a sailmaker or canvas shop. They'll be able to make and fit a soft top for your car.
Quote from Roulemabosse on July 10, 2017, 5:57 pmThank you for your input
