Older Harley sidecar on modern Harley Road King
Quote from tinkerer on October 2, 2018, 8:11 pmHi All,
I was wondering if you can put an older Harley sidecar from the 1980s on a relatively new 2009 Harley touring bike, like a road king. I've read some posts and a lot of them just say to buy the manual. Just want to make sure this is even feasible before buying the sidecar.
Thanks,
Tinkerer
Hi All,
Thanks,
Tinkerer
Quote from jaydmc on October 3, 2018, 7:24 amYou can if you do not mind doing custom fabrication. Nothing is available off the shelf . You also need to think about the brake, the early sidecar will have a drum brake rather then a disk brake. You might also think about if you really want to do this. All Harley sidecars even the very last one they ever built still had no suspension! Any modern sidecar (being anything built after WW2) will have suspension on the sidecar. Harley sidecars the wheel is ridged the body is on not dampened leaf springs. If you were to start over with most any of the made in America sidecars they will come with proper bike specific NOT universal mounts and when all is said and done, when you factor in what you can sell your current sidecar for you might be money ahead starting over.
DMC sidecarswww.dmcsidecars.com
Quote from hdsidecarron on October 3, 2018, 2:17 pmWhat year sidecar is it? The serial number can tell you the year of manufacture. If it is one made for a pre evolution it would be difficult. An evolution era sidecar would be a little easier. Parts are available from Harley because I checked on an upper front mount a couple of weeks ago and they were available.
HDSIDECARRON
HDSIDECARRON
Quote from jaydmc on October 3, 2018, 2:46 pmThe Upper front is not the issue, it is the lower rear that is the issue.
DMC sidecars866-638-1793
Quote from tinkerer on October 3, 2018, 7:56 pmThanks everyone. The Sidecar VIN is 1HD8SDX10BT010045, which I am interpreting as a 1981 model due to the B in the 10th digit. This would make it a Shovelhead sidecar, as the Evo came out in 1984 as I remember.
