MY HACK
Quote from Guest on August 9, 2013, 8:53 pmI JUST PURCHASED A 1997 FLSTC WITH A HARLEY SIDECAR
SELLER SAID IT WAS A 1995 I DONT THINK SO HAS OLD FENDER MARKER LIGHT AND TOOMBSTONE TAIL LIGHT
ALSO HAS DRUM BREAKS HOW CAN I DETERMAIN AGE JUST CURRIOUS
I CAN'T LOCATE A SERIAL NUMBER
HELP PLEASE
MARCO
HELP PLEASE
MARCO
Quote from Guest on August 9, 2013, 10:05 pmI BELIEVE IT IS HD LOOKS LIKE ALL OTHERS I HAVE SEEN
PIC ATTACHED
PIC ATTACHED
Quote from Guest on August 9, 2013, 10:07 pmHERE THEY ARE
HERE THEY ARE
Quote from Chuck on August 10, 2013, 8:18 amThat is a harley sidecar, could you post a couple more pictures of the sidecar mounting to the bike frame? that type of sidecar should have three mounting points. Top under the fuel tanks, front lower tied into the lower down tubes and the rear lower on the frame of the bike tied into the area by the passenger foot board.
I am curious as to how they did it and what may have been modified to do it.
Quote from Guest on August 10, 2013, 12:28 pmPIC OF MOUNTS SOMEONE TOLD ME HARLY MADE NO MOUNTS FOR SOFTTAIL BUT THESE LOOK LIKE OEM MOUNTS
Quote from Guest on August 10, 2013, 1:57 pmWASNT SURE GUY THAT PUT IT TOGETHER WAS A MILLRITE AT LOCAL STEEL MILL THEY CAN FIX ANYTHING
RIDES AND TRACKS WELL SO MUST BE PROPERLY ALIGNED
ANY IDEA OF YEAR TOLD BY SELLER 1995 BUT HAS OLD STILE LIGHTS AND DISK BRAKE
MARCO
MARCO
Quote from Chuck on August 10, 2013, 2:26 pmRear mount is home built like Lonnie said, the guy may have Used parts of oem rear mount seems I recall HD using the double u-bolt system on the rear of the bike frame I thought?
Your sidecar frame has a hydraulic drum brake those were used from 1997 on down, Now if you look on the sidecar frame that runs between the bike and sidecar body you may find a serial number either stamped there or a metal foil sticker tag. So it could very possibly be a 95
How about a picture of the lower and upper connections to the frame
