Mounting Sidecar on Triumph Rocket
Quote from Rocket2007 on January 21, 2015, 12:01 amDoes anyone have a sidecar attached to a Triumph Rocket 3? I am having difficulty working out how/where to attach the rear upper mounting point to the bike. Any input would be helpful. Also if anyone knows where I can buy a proper mounting kit for the bike, I would appreciate it. I am planning/trying to mount a Champion Daytona sidecar.
Quote from jaydmc on January 21, 2015, 10:38 amWe make mounting kits for the Rocket 3, we also make triple tree's to lower the steering effort however right now the only rocket 3 tree's we have in stock are for the tour not the standard rocket 3. Lead time on mounts is about 3-4 week right now, triple tree's 6-8 weeks.
Do you already have the sidecar?
http://www.dmcsidecars.com
Quote from Sidcar on February 28, 2015, 3:54 pmHi, I took these pictures of a nice Rocket Three outfit at a rally last year unfortunately neither show the fittings.
Sid
Sid
Quote from Rocket2007 on February 28, 2015, 6:03 pmSidcar, thank you. Nice looking rig. It was helpful as it shows how the bottom fitting goes round to tie in on the non-sidecar side of the bike.
Quote from pago cruiser on March 28, 2015, 2:19 pmNot to get too far off topic...
But could anyone please identify the fairing on that R3?
TIA
TIA
Quote from claude #3563 on March 28, 2015, 10:13 pmTo answer the original question we drill a 1/2" hole through the 'gusset' at the rear seat side in front of the upper shock mount.and install a eyenut there. LBS does the same thing. You must be carefull to get the hole positioned right as there are cast in stiffeners on the back side and the outside surface is not totally flat.
Quote from claude #3563 on March 29, 2015, 9:33 amThe upper front can be a threaded eyenut on the motor mount bolt if you take it out and turn it around. We put a pinch block on the eyenut and run a tube from it to the lower mount on the subframe. Not a bad idea to do the same in the rear to tie everything together.
Quote from Rocket2007 on April 1, 2015, 12:43 pmClaude,
Thank you for your guidance. Our spring tour often goes through Pennsylvania. Next time we will drop in and see you.
Cheers.
Chris. H.
Claude,
Cheers.
Chris. H.
Quote from DirtyDR on April 1, 2015, 2:08 pmI ran across this one a few years back at the AHRMA races at Miller in Utah. A bit of under kill on the sidecar and I did not get a real good shot of the mounting. I think I was more interested in getting the Cozy emblem just to prove that someone would put a Cozy on a Rocket Three.
Quote from Hack__n on April 1, 2015, 6:13 pmWonder if the guy in the pix was the pilot, or the monkey. If he was the monkey the bike to car weight ratio would be about right.
Quote from claude #3563 on May 25, 2015, 10:17 pmWonder who mounted that Cozy? We have turned away jobs that were less scary than that. BTW... We did a Champion a while back on a rocket , one of ours on one and also the LBS mentioned ealier. We are mounting an early Hannigan Astro on our own Rocket now. This is temporary as we will be putting one of our own sidecars on it at some point. Excellent sidecar haulers! They do beg for steering modifications though.
Quote from DirtyDR on May 26, 2015, 10:43 amThat guy rides that rig all over the place like that Claude and he said it handles fine. He is crazier than I am.
Quote from claude #3563 on May 28, 2015, 8:05 amDirtyDR - 5/26/2015 10:43 AM
That's all fine and well until he needs to make a quick evasive maneuver or whatever. Of course maybe there is added weight and maybe the mounts are reinforced and so forth. With modification I could see this being okay but many times we see pictures on th enet that give an impression that is not a good on. They say a picture is worth a thousand words but the words that are birthed by the picture may or may not be accurate. Bottom line: Sidecar mus tbe suitable for th ebike as wel as mounts and suspension and all that goes along with it. Cozy on Rocket 3
In stock form...no way.
Quote from tassie on June 7, 2015, 5:55 pmpago cruiser - 3/28/2015 2:19 PM
TIAlooks like its off a triumph sprint
TIA
Quote from Rocket2007 on June 7, 2015, 8:21 pmA belated thank you to both DirtyDR and Sidcar for the photos. Because of the issues with the kit supplied I ran out of time last winter to attach the sidecar so this is now a 2015/2016 winter project.
Quote from Gummiente on June 7, 2015, 10:04 pmDirtyDR - 5/26/2015 10:43 AM
Not only is he crazy, he's also riding on borrowed time. Hooking a Cozy to a Rocket III is like towing a 30' camper trailer with a Smart Car; it is completely the wrong vehicle for the job.
