Motorvations Formula II Hood
Quote from mike m on September 14, 2020, 4:31 pmAlthough I have no direct experience with a steering damper I'm told that it could make it harder to steer. Anyway, I did not need a damper. Yes I like my Heritage as a sidecar bike. I put solid Harley Fat Boy wheels on it when I put the new tires on this spring, because they're a tubeless tire and you can fix a flat on the road (if you have a tire repair kit) and you don't need to keep checking for loose spokes. I bought both wheels off of Craigslist for $300 (they're over $600 per wheel in the Harley catalogue)and they're a direct fit depending on the year of your bike.
Quote from AceinSav on September 15, 2020, 4:57 amBarbara, the need for modified trees isn't limited to any sidecar. it is a very good investment for ANY sidecar or trike
I installed 4.5 on my Wing with the the sidecar and I'm pretty sure it is a 4.5 that is on the trike I just bought my wife
Tires and head bearing tightness are the biggest causes of head shake, mine with a new front tire won't shake at all but as the tire wears and begins to cup ( and this is a given) it will begin to shake, as the cupping gets worse so does the shake. you have 3 options to control it
1 tighten steer head bearings a little more than stock specs,,,, this works very well, but the tire will still cup
2 add a steering damper,,, this will make your turning harder, and the tire still cups
3 keep your tire cupping ground down,,, works great, stops the vibration caused from the tire cupping, but is a pain to do
this is all based on Goldwings as I have no experience with any other bikes, but I'm pretty sure the front tire cupping goes with all sidecars to some extent
Quote from SwampFox on September 15, 2020, 6:24 amHi Barbara: We have no direct experience with a Softtail, but our Sportster rig also did not require a damper after installing Hawg Halter triple trees, which not only eased steering effort, but also eliminated much of the handle bar wobble, particularly when riding a bumpy road.
Quote from Barbara Behm on September 15, 2020, 8:26 pmThanks again for the input. I'm going to start with the triple trees and see where we go from there.
Quote from 2FLTC on September 16, 2020, 8:42 amHave a 82 FLTC stock tree's, I can pull 25k + out of the stock front tire and no cupping. Each bike is different.
Quote from AceinSav on September 16, 2020, 3:02 pmQuote from 2FLTC on September 16, 2020, 8:42 amHave a 82 FLTC stock tree's, I can pull 25k + out of the stock front tire and no cupping. Each bike is different.
sure wish I could say that. I think headshake and front tires cupping is just a Goldwing thing. all 3 Wings I have had have done it, even when riding on 2 wheels
Quote from R Clayton Greaves on June 17, 2022, 5:48 amThis was a helpful thread to discover as I begin my SC journey. I'll start a fresh thread, and YES Barb's rig is "suuuweet"
