Is PM Working??
Quote from Guest on November 25, 2008, 11:58 amI tried several times to send a PM. It keeps looping back that I must enter a valid username/password. I tried many times and no dice. Even logged out of the forum, logged back in the be sure I had the password correct. I am 110% sure I entered the username/password correctly on the PM form, but still kept failing. I am using Firefox if that matters.
Quote from Guest on November 25, 2008, 12:13 pmThe first thing to try is check your settings. Some people check the box to not recieve pm's when the sign up for the forum and the system just kicks things back to them. If that isn't the problem reset your password. That has cured other folks PM ills.
