USCA Sidecar Forum
Introduce Yourself!
PreviousPage 2 of 2
Tire wear in the center will go up front and rear with a sidecar. just a fact of life.Ā
I have the HanniganĀ  4 1/2 degree rake. Had 6 degree on the 2017.
Car tire on rear give a lot more mileage and better traction in wet weather.
What I do not want to end up with is that front end up in the air look.
What size/brand tire do you run on back?
Quote from David Bundy on April 12, 2023, 10:50 am
2020 RGL comes with 18 inch wheels front and rear . No 18 inch wheel will fit a car tire. So I use a 16 inch in the rear and a 195/65R16 car tire.
It comes out to the same height as a 180/55-18 and is about 6 tenths of an inch wider. Use a couple brands just depending on when I order one.
I am putting a new rear tire on April 18 th.Ā  Getting ready for Shark Week.
I wish HD had stayed with the 17 front and 16 rear they use on RG for a good bit. They hold up to pot holes much better.
David Bundy has reacted to this post.
David Bundy
PreviousPage 2 of 2
