Honda Goldwing with Armec
Quote from eagle1zero on June 26, 2018, 9:10 pmSince seeing the recent discussions concerning Armecs and I thought I'd add in my recent project that I finished up in May. I mounted a Armec Tremola II onto a 2010 GL1800 and so far the results, to me anyway, have been very rewarding. I'm pretty much a novice to the sidecar world but since I retired I've formed somewhat of an addiction to the fun factor they provide. Overall I couldn't find much information on mounting an Armec specifically the amount of info available from knowledgeable folks on this site provided a lot of insight into getting this sidecar mounted and setup. Anyway, thought I'd put a couple of pics out there and thanks for all the tippers.
Quote from Deleted user on June 27, 2018, 8:07 amEagle, Thank you for sharing. Are you in FLA.? My Armec in Ohio, my friends in Minasnowda, another in New Jersey,Rhode Island. Looks like you have a fuel tank under the sidecar?
Quote from eagle1zero on June 27, 2018, 8:24 amDave, I'm in NW Florida Panhandle. Have to admit that sidecars are a true oddity in this area. Thanks for the info on other armecs around and I'm sure you have found yours as fun as I have this one. Yes, it does have an aux tank on it. Had to do a bit of a compromise on overall width due to the fill location and wanting to still make the right bag useful to the extent possible.
Quote from kfskmccall on June 27, 2018, 12:31 pmA very sporty looking rig!
What made you choose the Armec over a Hannigan GTL?
Based on your photos, it appears to be rigidly mounted.
Ken M
Ken M
Quote from eagle1zero on June 27, 2018, 1:33 pmKen,
I came across the Armec awhile back and snatched it up when I saw it. It wasn't really choosing one over the other and the GTL is a great sidecar. Actually it, the GTL, does have the one advantage of electric camber control which the Armec doesn't have, although I haven't found that to be any problem at this point. Yes, the sc itself is rigid mounted.
Ken,
