Help identifying version of California sidecar
Quote from Guest on March 14, 2013, 7:20 pmPurchased this last summer, (97Heritage w/113ci S&S) with California Sidecar. I think it's a Frienship 1, but not sure. It does have coil over shock suspension and stabilizer arm. Just can't find anybody close to Augusta, GA that knows much about them... Any help is appreciated.
Quote from Hack__n on March 14, 2013, 8:18 pmThis is a California Companion (the model that preceeded the Companion GT which is a bit wider and heavier). Produced sometime after 1989.
Quote from Guest on March 14, 2013, 11:29 pmGreat looking rig there, Max! Hope it runs and rides as good as it looks. Many happy miles to you!
Quote from Guest on March 20, 2013, 11:15 amThanks for the quick reply.
Quote from New York Bear on May 15, 2013, 5:36 pmThis makes me curious, as to why California sidecar has coil over shock on this sidecar, but still used the torsion bar suspension on the Friendship 2, in similar years? Any one have a clue?
Quote from Hack__n on May 15, 2013, 6:27 pmWith the separate fender styling. It was easier to convert to the more efficient coil over shock. The Companions also were able to run a much larger wheel and tire.
Quote from Guest on September 27, 2013, 12:42 amIs there a specific manufacturers sidecar out there that would fit my 2000FLH as well as be compatible with a newer FLH model (most likely a Roadglide?) in the future if I were to get a new bike? Wishful/hopeful thinking right now. :O
Quote from Sidewise on September 27, 2013, 8:17 amAny of the larger heavier sidecars would be compatible, it's the mounts that
would need to be changed. For HD I prefer the looks of Liberty sidecars.
See here: http://www.libertysidecars.com/
Quote from jaydmc on September 27, 2013, 7:13 pmWe have several sidecars that work well with the FLH. Our M72C the M72CX and our Expeditions sidecars work well. The Kenna is the least expensive sidecar we have for these bikes.
These sidecar come with bike specific mounts.
http://www.dmcsidecars.com
Quote from wvsporty on October 4, 2013, 1:00 pmHey thats one sweet rig yo got Mad Max.....and LOTS of chrome too.
David , I like the matt619.....as they said above most sidecars will work its just the mounts change as the bike frame changes..I also like the looks of some of the www.trans-moto.com units specially the Harley factory look unit which ahs the suspension onthe sidecar wheel and not the body. Its all up to your style and pocket book from open air rigs to fully enclosed and everything inbetween
David , I like the matt619.....as they said above most sidecars will work its just the mounts change as the bike frame changes..I also like the looks of some of the http://www.trans-moto.com units specially the Harley factory look unit which ahs the suspension onthe sidecar wheel and not the body. Its all up to your style and pocket book from open air rigs to fully enclosed and everything inbetween
