Help identifying a sidecar
Quote from Guest on January 18, 2009, 5:06 pmAnyone got a clue on this?
Quote from Guest on January 18, 2009, 5:09 pmPics arent working. Let me try another way.
Quote from Guest on January 18, 2009, 7:50 pmAnybody? Are the pics working?
Quote from Guest on January 18, 2009, 8:40 pmPictures are working fine. Nice find there...looks like something I'd drag home!
How about a clear shot of the rear?
I can see a Triumph decal behind the cockpit perhaps the other numbers and letters will give a clue.Don in Nipomo
Don in Nipomo
Quote from Guest on January 18, 2009, 8:42 pmPics are working, but haven't got a clue as to make.
Quote from SidecarMike on January 18, 2009, 10:38 pmI think it's an International. Judging by the rib on the nose and the style of fender.
Quote from Guest on January 18, 2009, 11:38 pmI'll get some better pics tomorrow out of the truck. It has been raining here all day, that why those were so crappy. it does have a couple triumph decals on it, but they appear to be non factory(crooked). I have looked it over and have found no numbers or signs of a vin plate what so ever. Thanks for the input and I will have better pics tomorrow nite.
Quote from Guest on January 19, 2009, 1:39 amI'm not saying it is but my California Companion has the same indentations in the front, might be a early one.
Quote from claude #3563 on January 19, 2009, 7:43 amIt is an international like Mike said. The Watsonian Flight sidecars were similar but the way I understand it had a fin on the rear deck.The attached picture below says 'flight' but it is an international sidecar.
Click here to see a Watsonian Flight with the fin. Very similar to the international sidecar :
http://www.geocities.com/cook_jerry/SIDECAR.html
Quote from SidecarMike on January 19, 2009, 11:45 amThe Flights also had the lights molded in to the fender.
Quote from claude #3563 on January 19, 2009, 12:39 pmOriginally written by SidecarMike on 1/19/2009 11:45 AM
Mike,
Were the flight fenders like the one in the link I posted? http://www.geocities.com/cook_jerry/SIDECAR.htmlIn other words the same as other Watsonians??
Reason I ask is that we did some work on and mounted a 1954 Watsonian Avon (see attached) and the fender on it was totally different.
Mike,
Quote from SidecarMike on January 19, 2009, 1:50 pmOriginally written by claude #3563 on 1/19/2009 10:39 AM
Mike,
The only ones I've seen have been 60's and early 70's vintage, and they all had the lights molded in. Even then, I'm no authority on English sidecars. I really couldn't say about one that old. Maybe this would be a good question for Doug B.
Mike,
OK. Here are some better ones....
Quote from Guest on January 19, 2009, 9:40 pmHope these pics will help. Any idea where I can see pics of one original? What about year model? maybe a rough idea of what its worth? I got this in a swap with a buddy, but he is also clueless about it(he thought it was a Triumph because of the decals). Thanks for all the input!!
