Guzzi alternator output
Quote from Photozone on February 11, 2017, 11:50 amI have a 2004 Moto Guzzi California Stone with a Ural sidecar which is wired for 2 headlights, camber control and a couple of extra horns. I have not been able to find Alternator output for this bike. My question, is the Guzzi alternator capable of charging a car battery? Hopefully it will never have to charge a completely dead battery. I appreciate any insight you can provide. Thanks
Quote from jaydmc on February 13, 2017, 10:52 amThe size of the battery does not matter, think of it as a storage tank for electricity. A car battery is larger and as such simply takes longer to fill. No idea what the Stone's charging system puts out as it is plenty adequate. The Camber control is only used briefly so it does not make much difference. The two headlights are on all the time but if standard bulbs are used only draw 110 watts of power. Your charging system can handle this and even electric heated riding gear (at least my old EV could which is pretty much the same bike)
http://www.dmcsidecars.com
Quote from Photozone on February 14, 2017, 4:08 pmJay thanks for your response. I think it is a bike you folks built some time ago. It originally went to Houston. It has bike and sidecar subframes, camber control and hydraulic disc brake. It also has a leading link fork. Not a Unit so that also might be yours. Jet black bike and Ural. Very good looking and a very sweet ride. I have built 5 and been happy with all of them but never could have afforded to built this one. I am really going to enjoy this ride.
Quote from WinginCamera on March 12, 2017, 6:08 pmI am not sure if this will apply to a California Stone, but I once had a 1974 Guzzi Eldorado 850 that I replaced the original generator with one from a car, I believe it was from a Fiat, or maybe VW. It was over 40 years ago, my memory is not so good.
