DMC on a 1998 Moto Guzzi V11
Quote from rtbain on February 16, 2017, 5:04 pmInstalling a DMC sidecar on a 1998 Moto Guzzi V11 (California). Several items have been changed/upgrades prior to this post. I'm at the point where another pair of eyes is recommended.
Changes made to date:
1. Final drive exchanged for lower gearing
2. Ignition moved to battery compartment
3. DMC triple tree (easier steering)
4. Lower, wider bars
5. New brake lines (bar change and sidecar brake addition made this a good idea)I stole Jay's idea and built a cart for holding the hack when fitting. Life is good. 🙂
Quote from Hack__n on February 17, 2017, 7:01 amWe used to fabricate these sidecar dollies 25 years ago and sell them for $99.00. Two heights, 13.5 for URAL and high cars and 7 1/2" for Velorex and lower cars.
The steel and labor are worth more than $99.00 these days.Harbor Freight now has moving dollies for about $7.00.
Quote from jaydmc on February 17, 2017, 10:11 amNot sure just what the actual question is. So far what you are doing looks good however you really do need to put the wheel on as you will align off of it, while in theory the axle is square to the frame, due to production tolerances it may be a bit off, not enough to see but enough to change alignment.
http://www.dmcsidecars.com
Quote from rtbain on February 17, 2017, 3:20 pmTried using a furniture dolly and scissor jacks. I prefer the dolly, more stable. The casters were the expensive part.
Quote from rtbain on February 17, 2017, 3:27 pmHey Jay, just the man to ask. Meant to post the question yesterday but got sidetracked.
My problem is the heim joint engagement in the rear mount. By my measurements only 3/8" engagement is possible with "proper" alignment. See pictures below.
The bike is squared up. The hack frame is squared up on the dolly. I do understand the wheel needs to be on for the alignment but wanted to sort out everything first. I also understand final adjustments should be made with the suspension normally loaded.
This is a bit frustrating as the images can only be added (to the best of my knowledge) after the text is posted. Please have a look at the attached photos and see if you can see where I am going wrong.
Quote from jaydmc on February 17, 2017, 3:34 pmNormally the joints go straight on parallel to the ground. Try rotating the clamp. You may have to cut some off of the boss so that it does not hit the ground. We do make bosses with longer ends for the hiem joint if need be.
Quote from jaydmc on February 17, 2017, 3:38 pmYou might find it help full to go to our site and watch the second and third video's http://www.dmcsidecars.com/video/
This link also has some good photo's that might help you http://www.dmcsidecars.com/the-result-of-improper-sidecar-mounting-and-the-proper-fix/
Quote from rtbain on February 17, 2017, 3:48 pmI have seen the videos. They are well made and clear. Unfortunately I can be an idiot at times. Finally figured out the correct orientation thanks to your kind guidance. Photo below.
Quote from jaydmc on February 17, 2017, 4:02 pmFor street applications we recommend 10 - 15 % of the wheel base of the bike.
Quote from CCjon on February 17, 2017, 5:02 pmEasy to remember guide - Lining up the sidecar axle with the front of the rear tire will work out to just about the 10 - 15% rule that Jay mentioned.
Quote from rtbain on March 24, 2017, 6:43 pmEverything mounted and test ride completed. The DMC tree made a huge difference in ease of steering.
Quote from rtbain on March 25, 2017, 8:39 amDoes anyone have information on suspension set up? Looking for new springs to compensate for the added weight.
Quote from rtbain on March 29, 2017, 9:43 amProgressive does not have direct kits for the EV. I am trying to find:
Spring dimensions and rate for the forks.
Spring dimensions and rate for the shocks.
Quote from SwampFox on March 29, 2017, 10:06 amMight check with Ikon Suspension USA. The former importer was very helpful re: replacement shocks for two of our rigs.
