Quote from RichardM on November 24, 2012, 3:56 pmI need to replace the rubber rings that suspend the body from the frame on a Cozy Rocket. Is there a simpler procedure than just brute strength for getting them installed? I currently have the body off the frame and thought that this may be a good time to replace them.
Thank you
Thank you
Quote from Cozy1 on August 11, 2019, 4:07 pmI realize that this is an old post but.... There is a bracket that the rubber bands are attached to. If you reach inside of the trunk there are nuts that attach to this bracket. remove the nuts and the pressure on the bands is relieved and makes this job pretty simple
Kevin Mahoney
Cycle Sidecar
Kevin Mahoney
Cycle Sidecar
