comments in albums
Quote from grumpycrw on April 23, 2011, 4:28 pmsomeone is leaving add posting in my comments
how do i get rid of them
can i stop them from sending them
i lost one picture trying to clear them
Quote from SidecarMike on April 23, 2011, 5:08 pmgrumpycrw - 4/23/2011 3:28 PM someone is leaving add posting in my comments how do i get rid of them can i stop them from sending them i lost one picture trying to clear them
I got rid of them for you. Joyce, I thought we were set up so guests could not post comments? His were all from a guest account.
Quote from Guest on April 23, 2011, 7:31 pmI know only registered users can post to the forums but I could never find a place to block the album comments from unregistered users.
Quote from SidecarMike on April 23, 2011, 11:35 pmI just enabled Flood Control. This will limit users to one post every 4 minutes. It should kill any auto-robot type of posts or comments, but won't help with someone posting a single one.
I don't think this should be a hardship to our users, but it can be turned off if it is. Please let me know if it causes a problem.
I can't find any way to limit album comments either.
Mike
Mike
Quote from grumpycrw on April 24, 2011, 12:35 amchecking out other albums i see that 90k75s albums has 368 comments
if it happens again is there any way to delete them
Quote from Guest on April 24, 2011, 10:34 amIt is easy to fix I think. Go to albums, click edit your album at the upper right. Pick the name of the album to edit and at the bottom are two boxes. Check the box that says allow registered users to add comments instead of the unregistered users and you should be set.
