USCA Sidecar Forum
Car tire installation recommendation?
12
Several folks I know run 165/60-14 on the back of their Burgmans. No problems that I have heard of. My local shop will replace and balance for $20 if I bring him the wheel.
J.R.
USCA Sec.
Tex Rep.
VLAD - 4/26/2018 8:14 AM As far as i know 195/55R-16 will not fit GL1500. It will fit 1800 but not 1500. I have 175R16 installed and clearance in swing arm is minimal.
In this thread, one of our members reports that he's using 195/55-16 on a 1995 GL1500. http://www.sidecarist.com/mbbs22/forums/thread-view.asp?tid=15389&posts=23&highlight=austone&highlightmode=1#M96809
He got the wheel mounted and balanced then, to install it, he let out all the air first. Ha! Pretty tricky! Once installed, he re-inflated. Pretty good trick.
There's also this thread where a member says a 195/55-16 fits, but he saw where a tire made by Yokohama in that size that was too wide and rubbed the swingarm. http://www.sidecarist.com/mbbs22/forums/thread-view.asp?tid=14891&posts=25&highlight=austone&highlightmode=1#M93802
Of the three tires I mentioned yesterday, the Ecopia E422 Plus is about 3mm wider than the other two, which would suggest maybe the Altimax might be a better choice.
Caveat--VLAD actually owns a GL1500. I do not, and never have. I'm just going off Post #6 above and stuff I've seen on the web. If you want to try VLAD's Austone tire, it looks like they are in stock at Universal Tire-- https://www.universaltire.com/175r16-austone-taxi-black.html The Austone tire is pretty close to the size of your OEM 160/80-16 tire. It's about one centimeter taller and about a half centimeter wider, so almost a perfect match size-wise. As an alternative, Universal Tire also sells the Dunlop Taxi Tire in the same size.
So far bentleyssq is only one who saying he install 195/55-16 on 1500. Everybody else saying his brother in low best friend sister knows somebody who did it. I did install 175/55-16 , 175R16 and other one on my bike. All of them have 3/8" to 1/2" clearance in swing arm. I see no way to install 195/55-16(20 mm wider more then 3/8" on each side), but if bentleyssq saying he did install 195/55-16 on 1500 I trust him. Some tires is little smaller or little bigger then they have to be. I did not like 195/55-16 it is smaller diameter then OEM so your bike will be lower - smaller ground clearance. 175r16 is little taller and i like it better.
Remember to readjust your rig after you install lower or taller tire. Otherwise you will replace it soon.
Online
Here is my post on the install of a 195/55/16 Federal Formosa on my 1995 Goldwing. I installed it myself on the rim, inflated it , then deflated it to install. Just some wiggling and it went in with plenty of clearance. I have over10000 miles on it. No problems. See the pics. I have an extra rim and another tire I bought same type and brand that I have in the garage as a replacement when this one wears out. I will fit, I don't know about other brands. I saw and article on "Goldwing Docs" about a person who installed that tire on his wing (with Pictures), his bike was Green Search the Goldwing docs site for "Car Tire". It fits, no mods to frame or swingarm.
Regular
Positive about the size You can see it in my pics and I’ve included a few more . No issues with rubbing or anything. 195/55/16.
Some reason I copied and paste and photos not showing . Rewiew my post, in SEARCH, type in Federal Formasa and it should pop up. Thanks.
12
