bank angle sensor
Quote from oldxrider on May 14, 2018, 8:01 amCould someone explain why on an HD when a sidecar is installed a bank angle switch kit is also required. I was under the impression that HD's have a bank angle sensor that kills the ignition if the bike is dumped, is the sensor defeated for sidecar use and why?
Quote from Al Olme on May 14, 2018, 12:20 pmGreat Question! I called one of advertisers in The Sidecarist [the USCA club magazine], Del Zane owner of St Croix Harley Davidson / Ural. He said that the sensor was defeated so that if a person flew the chair, the sensor would not shut down the engine. Thanks, Del.
Quote from Lloyd on May 14, 2018, 5:01 pmMany years ago, when I first took a trike class, I remember the instructor saying the bank angle sensor needed to be defeated on any non leaning bike, as it could shut down the engine on a hard turn. He explained that what ever hangs in the container suspended in oil could swing far enough to touch the side and close the electrical switch.
Quote from oldxrider on May 14, 2018, 7:53 pmMakes more sense that cornering forces could trigger the switch, I can't imagine flying the car high enough to simulate a dropped bike.
Quote from Jeff_Online on May 14, 2018, 10:37 pmThe turn signals don't work correctly. They change the auto cancel for a time-only unit. I think that's why, anyhow.
