Ballast
Quote from Guest on May 7, 2011, 10:15 amAs a newer sidecar owner, where is the best place internal od the car to place the ballast. I have had a few different ideas from behind the seat to evenly spread thougout the car. Just need experienced hackers to help. Thanks
Quote from Deleted user on May 7, 2011, 10:57 amBack and outboard
Back and outboard
Quote from Hack__n on May 7, 2011, 11:41 amPlace soft or secured ballast material behind (or under) the seat. To the rear of the body and to the right side (US) if you can.
Movable hard ballast can severly damage the body if it shifts during a hard maneuver. Weight in the front end can cause the the car to dip it's nose into the sand, or worse the pavement, if braking in a hard left turn, or downhill.
I've seen many URAL rigs with road scars under the nose since they have little wheel lead and are heavy cars.Lonnie
Quote from SidecarMike on May 7, 2011, 7:42 pmWeight in the front also increases the tendency to shake the handlebars (tank slapper).
Quote from Guest on May 8, 2011, 4:04 pmThanks for the info. Will let you all know how it goes. Also, looking to get a headlight for a Velorex 700 car. Any suggestions?
Quote from SwampFox on May 8, 2011, 6:20 pmHey Bulldog:
I'm a little slow to respond, but I have a 25 pound barbell weight positioned as far out and back behind the seat of the Texas Sidecar as I could. It is zip-tied several times to a piece of thin plywood cut to fit, painted black and bolted to the floor by the main body to frame bolts, with the weight wrapped in black "trunk carpet."
I would rather have the weight mounted to the frame under the car, but I can't weld or fabricate, so was my compromise using extra stuff lying around the house/shed.
Hey Bulldog:
Quote from Guest on May 8, 2011, 8:45 pmi do something similar with a lead brick. it is about 25lbs, and i also have 25lbs bolted under the frame. i bought a piece of 3/4 iron plate and had it cut about 3" by 40?" had holes drilled and have it attached toward the out-board using the bolts that attach the body to the frame. this makes the sidecar weigh about 175lbs. i have to have half my ballast portable because with the sidecar being so light the suspension is too weak to handle a total over 375lbs with passenger. so when she is with me i stow the lead brick on a luggage rack mounted to the rear fender of the bike.
Quote from Guest on May 13, 2011, 9:49 amLittle follow up. If I want to use the bags of shot, where is the best place to get it. I have seen it as much as 3.45 a pound. The best so far was on EBAY and that was 2.45 a pound. Any help would be appreciated.Ebay shipping can be prohibitive. Usually the best source is a local gunshop, or put a wanted ad on Craigslist. Someone out there will have a reloader and big stock of shot. I used to buy 10 bags at a time and got it for about 1/2 price.
Quote from grumpycrw on May 14, 2011, 8:15 ami got a 50lbs of sand at homedepot under 3 dollars
i used sip lock bags large
full the wieght 10lbe to much bags brake open
then i tryed halk full 5lbs work find
i used two bags to make sure that they don't brake
i spread out 10 bags under seat and in trunk
i carry 50lbs all the time i also have anouther 10 bags
for when i need them at 5 lbs i know how i am putting
in or outi cut a pice of carper to cover don't even know that is there
cost under 10 dollars
in or out
Quote from Hack__n on May 14, 2011, 11:02 amThe fabric tote bags from Home Depot, Walmart, etc. will hold 50# of sand wrapped in plastic bags and are easily handled. I used to use pickup traction sand tubes for my new clients to start out with but these are much easier to lift into the sidecar trunk. Inexpensive and no potential body damage with these.
lonnie
lonnie
Quote from grumpycrw on May 14, 2011, 8:15 pmthat was my first try
imoved seat back rest to open trunk
i tryed to put the tote 50 lbs in
i ended up pulling my back out, didn' do much for a few days
have to brake down the weight
i do use the totes 4 per tote and they still lay flat
Quote from Guest on May 15, 2011, 6:57 pmGoing to look into that. Not having much luck in the shot department. Found some on Ebay but they want a lot on money. Thanks for that info. I am sure I will have more questions as I go along. This is a great site and forum for infomation, glad I found it. Everyone ride safe. Thanks again.
Quote from tmuilenberg on May 16, 2011, 3:32 pmI use a 5 gallon water jug from the camping supplies dept. of Academy. At 8.345 lbs. per gallon, the 5 gallon jug weighs just over 42 lbs. Add more to suit. There is no chance of damaging body work with these.
If you pick up a passenger just empty the water and off you go. Refill when necessary.
Terry
Terry
Quote from Lloyd on May 17, 2011, 1:08 amI checked Midway USA, a mail order, internet shooting supplier a couple of months ago, their price for lead shoot was pretty reasonable at the time. I haven't ordered any yet but, it was the best price that I could come up with. My thoughts were to put it in 3 inch clear vinyl tubing from Home Depot with wooden plugs secured with hose clamps on the end, in lenghts that would make up about 25 pounds so that I could handle it. Don't know if this would really work, but it sounded reasonable to me.
Quote from Deleted user on July 4, 2011, 9:05 amOld blue jean legs filled with sand work good. They can be cut to fit almost any where and are cheap. J.R.
Quote from Guest on July 10, 2011, 11:00 amWhat's ballast? (jk) Aint it more fun to run without? I have a 86 Goldwing Aspy with a Champion Escort and never run ballast.
Quote from Al Olme on July 10, 2011, 1:44 pmI don't use ballast any more but then I always have a bunch of junk in the sidecar trunk so maybe I do. ;^) Anyway, I've got a bunch of old cast iron window sash weights that I can't bring myself to throw away. If anyone wants them and will pick them up in Minneapolis, they're welcomed to them. Shipping costs would be ridiculous. [TLMaryann would be pleased to see them go!]
Quote from Guest on July 11, 2011, 8:38 amThanks a bunch guy's. I finally used sandbags. Got it pretty much down now. I have a Venture Midnight Star with a Velorex 700. Was worried about it at first, but after calling Velorex and having a great installer hooking up the car, I am really surprised how great this car and bike work together. I have no car slapping, no pull, no wheel shake no problems at all. I am just so pleased with it. I want to thank all who have helped with this.
Quote from Guest on July 27, 2011, 9:46 amOne of your users mentioned our stainless steel shot bags as an option for ballast a few years ago.
I want to remind you that we still make these ballast bags. They're made of tough genuine CORDURA and filled with stainless steel (*NOT* lead) in weights of 5 pounds, 8, 10, 15, 20, and our most popular 25. They feature a dual-pouch butterfly-with-handle design for easy use and storage, as well as precise weight placement.
If you have a different design you'd like, tell me about it and we can make it for you.
http://www.lowinglight.com/shotbags.shtml
We want to help make your riding experience as safe and exciting as it can be.
Thanks!
-- Steve at Lowing Light & Grip
Thanks!
