Alignment
Quote from MrGoWing on March 11, 2017, 2:53 pmHello Just setting up to install and old Hannigan Astro side car onto my 2001 Honda GL1800 Goldwing and I have question regarding toe in. I have bungied an 8' fluorescent tube to the rear tire of the bike and another to the wheel on the sidecar. Where are the reference(rear) and the toe in(front) measurements made?
Thanks from still snowing Edmonton
Quote from Hack__n on March 11, 2017, 5:35 pm1 degree to 3degrees. Hannigan has recommended up to 6 degrees for one of their cars I the past which proved to be 3 degrees too much
NWSC
Ret'd.
NWSC
Ret'd.
Quote from MrGoWing on March 11, 2017, 5:47 pmThanks Lonnie. Hannigan suggested 1-2 degrees with the rear shock fully preloaded. What I need is where to measure the 1" of toe in for the side car.
Quote from CCjon on March 11, 2017, 10:14 pmMeasure straight across, right behind the rear wheel and right ahead of the front tire.
1" of toe in is a good place to start. Since every rig and rider is different, set at 1", test ride on a flat straight road to see it it pulls one way or the other, then adjust accordingly.
Good luck
Good luck
Quote from Hack__n on March 12, 2017, 2:03 pmMeasure with the gap between the front wheel of the car with the rear bike wheel snug against the rear wheel. Using a straight edge, the front will have a 1" less measurement.
Quote from jaydmc on March 14, 2017, 10:09 amAs the GL is about a foot longer most bikes you are measuring over a longer distance as such to get the same amount of toe in that you would have with a shorter bike you will need to set the toe closer to 1 1/4 inch.
