Album comments gone wild
Quote from Hack__n on August 20, 2010, 12:11 pmI noticed a gang of fresh comments listed on an earlier album of mine from a few years back.
When I checked I found that guest spammers had added hundreds of ads for Cialis, insurance, and other spam, using the albums section as another advertising media.
This has got to use up a lot of space here. I'm probably not the only one this has happened to.
Can the comment option be limited to members only? If not perhaps that option should be discontinued.Lonnie
Quote from Guest on August 20, 2010, 2:41 pmGood call Lonnie, even my little album is filled with designer handbag scam ads! 292 comments.
That is a problem...Don in Nipomo
Don in Nipomo
Quote from Guest on August 20, 2010, 2:54 pmOK, I'll see what I can do!!!
Quote from Guest on August 20, 2010, 3:04 pmThey comments all seem to be posed by Guest's so I've changed the settings to only allow comments by registered users. I can delete the comments one at a time so it may be a while before I get them all cleared out. If your album has been spammed point me in your direction.
Quote from SidecarMike on August 20, 2010, 4:59 pmIt's a pain, but you can delete them yourselves as well, and help Joyce out. Mine have been hit too.
Joyce, I'll clean mine out.
EDIT: I found a quick solution. Save your photo to your computer, then delete it from the website. Now upload the photo again. When you delete it, all the comments go too.
Quote from SwampFox on August 20, 2010, 7:51 pmNow we know why there were 200+ guests online one evening earlier this week.
Quote from SidecarMike on August 20, 2010, 8:54 pmIt's been going on for a while. Mine started on 8-5-2010 and increased daily. If you go into my odds and ends album, there are comments posted today since I deleted them, but now all it says is Guest, and a blank post.
Quote from Guest on August 21, 2010, 12:23 amI had 292 comments, none of them on the rig....
Deleting one at a time will take a while, gotta be a shift inclusive path towards "delete all".
Parasites...Don in Nipomo
Parasites...
Don in Nipomo
Quote from Guest on August 21, 2010, 7:09 amDon, I got them. Turtleman57 you have 11,821 comments in one album and 569 in another and I hope you will follow Mike's advice and upload the photos again. One thing I noticed as I was editing was that even though I've changed the forum settings the albums infected still had a box checked to allow guest posts. I'll go through the recently updated list and check, but this might not be the end of the spammers.
Quote from Guest on August 21, 2010, 9:08 amThank you Joyce, I appreciate that.
Don in Nipomo
Don in Nipomo
Quote from Peter Pan on August 23, 2010, 11:22 amHow is it done to check the guest comments. Or am I lucky and there are no comments on my photos?
