Quote from
jaydmc on February 6, 2017, 10:24 am
We have done over 1000 GS sidecar rigs, we may have built this one or at least sold the sidecar as we build a lot with the Ural disk brake wheel. The wheel bearings leave a lot to be desired with these wheels as there is enough play that when you go around a corner the brake rotor often moves enough to push the pistons for the caliper back making it so you have to pump the brakes. The final drives do not seem to go out any more with or with out the sidecar, when it does we would run the final drive from the R850R.
I own and ride GS sidecar bikes, they work out well.
http://www.dmcsidecars.com
15616 Carbonado South Prairie RD
Buckley WA 98321
Hours Monday - Thursday 6-4:30
